[QUOTE=unique electric car;9899]Hi gottdi, Good, somebody here has a voice. OK, lets get to it. The Nissan leaf 192 lithium cells, each cell should be monitored, and charged separately a wiring “nightmare”. If even one lithium cell fails the hole battery pack could go out. Also, the batteries are under the passenger compartment, not good for maintenance,and I wouldn`t want to be in the back seat if the lithium batteries caught fire. Looking forward to your rebuttal.
Tom Sines:scared::scared:[/QUOTE]
All the cells are monitored in the Leaf.
If one lead acid battery goes out you can loose power too.
Batteries are low and out of the way for stability and room. Keeps the center of gravity low where it needs to be.
No maintenance required. If for any reason it happens that way I have full warranty for the next 8 years anyway at no cost. The blessings of buying a car from a manufacturer is the warranty. Home built has NO warranty.
Lithium cells are fully encased in steel. No fire. It requires oxygen to burn.
Also my vehicle is crash tested and has a 5 star safety rating.
Yours has none and is a fiberglass bodied vehicle. Ouch.
My vehicle has plenty of room. Yes too much most of the time but then again I don’t have to crawl into my car. I just get in.
I do like the creature comforts of my vehicle.
I have driven reproduction type vehicles and quite frankly most are just too small inside for my large size. Most have low roofs and my head hits the inside. I don’t like to scrunch down in my seat.
So for ME this is a good vehicle.
I am converting a 67 VW Panel Bus and we are planning on it being a 150 mile at 55 mph vehicle when done. Fast charge in 30 minutes and off and running again.
No drive by wire on the old bus.
Oh by the way. The Leaf is drive by wire. Fully. But yes, it has a steering wheel. I think your idea of the joy sticks is cool but not overly practical. Mostly because folks would need to relearn how to safely steer the thing. You have time but others will just want to get in and go with no thought.
It is just a keeping of the status quo. Not that one is better than the other. Not sure though if its actually legal but I don’t really care. I think its required to have a full wheel for driving. An old law or something like that. Just not sure. Been so long since I heard any thing or read anything about the issue.
Pete
OH yes. My conversion will not have a BMS or any complex monitoring system. Won’t need it with the LiFePO4 lithium cells we will be using.
