I’m looking to buy a 25s lithium system from Dave to put into my gem. I’m hoping to using the original charger without a BMS. Dave said that is what you are currently using. Any thoughts on using the stock charger with the lithium batteries? Do you have any other battery modifications (shunt balancer, etc.) that you’d suggest/not suggest?
My 2014 gem set on gel, charges my 25s lithium pack perfectly to 85.5 volts
At this point I am not using a BMS or a shunt balancer. But in monitoring the cells to see if they’re needed
20 should be perfect. I use it as a golf cart and only NEED about 15 miles. Ideally, I’d like more than 20 miles but that should do the trick…at least to start with.
I just found out I’m coming to the cities this weekend for the Final Four. Was gonna check with you to see if you had a pack ready to go? If so, can I pick it up Monday morning?
Hey, I just thought of something. How would you like a once in a lifetime chance to get a Chevy Bolt pack with out shipping cost? They are tough to ship.
A lot more money, but 12kwh. 50-75 mile pack. $2500
Ask Grant about them.
I’ve been looking for on the last 6 months and finally have one coming in.
Plan was to leave it on the shelf until I get my LIFEPO4 sold, but I need to break it down for Grant and Michael.
This was my first one.
