And it begins
Step #1 will be to link the battery’s together and get all the balance Leeds hooked up to the BMS.
Your getting good at this!
I think the key to these conversions is a Volt Meter. You think what your doing is right but the Volt Meter (if you listen to it) will never do you wrong. I have blown up like 3 BMS’s because I was not using my Volt meter the way it should be.
The JST plugs can be off by just a few volts and POOF. Your project just got side lined by 3+ weeks. If you double check and then re check your voltages you are way ahead of the game.
Yep! You don’t know squat until you can measure it!!!
Where is the neutral jumper?
Are we there yet?..
No I have stalled. I need to buy a transmission. I’m up in the air weather to buy a complete new car (in bad shape) for $500 or a used transmission for $250-$300+ shipping on Flea-Bay.
grant tell me about the new car in bad shape ? i’m looking for a donor
I love watching these conversions. I wish they weren’t so far above my comprehension level
Mike the car I was gonna Take the transmission out of is in pretty bad shape
