I am doing an electric motorcycle conversion. Electric Motorcycle
I got almost everything I need right at $2000 USD. I have compiled a complete list of parts so if I decide to do it again I have it all nailed down and wont have to do the hunting around I did this time. I have listed some parts different than what I used as I am learning a ton with this first project. The list I have made up is everything I will need to make another motorcycle not including a donor bike and it comes to almost $2100 USD. I am sure the price will change +/- a bit as I might use different batteries and things do go on sale and ebay is wonderful most of the time…
http://www.beepscom.com
Motor Perm-Motor PMG-132 12-72 VDC $895.00
6FT Cable Welding 4 Gauge - Black @$2.39/FT= $14.34
6FT Cable Welding 4 Gauge - Red @$2.39/FT= $14.34
Fuse ANL Holder $14.95
Fuse ANL 300 Amp $4.50
Controller Kelly PM 24-48 Volt Regen 400 amp $315.00
Throttle Magura 0-5K Twist Grip $39.95
2 Lug Magna Straight 4 GA 1/4" Hole @$1.55/EA= $3.10
4 Lug Magna Straight 4 GA 3/8" Hole @$1.55/EA= $6.20
6 Lug Magna Straight 4 GA 5/16" Hole @$1.55/EA= $9.30
http://www.evparts.com
DC2415 DC-DC Converter, 10 amp, 30-60 VDC in, for
nominal pack voltages of 36 & 48 volts, 11.8 to 12.2 VDC out,
non isolated $ 34.95
http://www.electricvehiclesusa.com
Emergency Push Button Switch $93.95
Rated 500 amps continuous,
5000 amps surge at 12 volts;
and 250 amps continuous, 2500 amps surge at 24 volts.
You should be able to run this switch up to
72 volts at 150 amps continuous.
http://www.applied.com
40 Chain, 15 Tooth, 0.75 in Bore, With Keyway and Setscrew $13.27
Part#: 40B15F3/4HT
Item#: 7671419
40 Single Strand Chain, 54 Teeth, A Style, Steel Sprocket $24.68
Part#: 40A54
Item#: 4475497
#40 Chain; 1 Strand; Riveted; Carbon Steel Material; 10 Foot Box $13.70
Part#: 40RIV
Item#: 8440007
Sub Total = $1498
shipping = $66
Total = $1564
http://www.kipoint.com.tw/
48V 20AMP ( 110V/220V Auto Switch ) Battery Charger $169.00 + $79.00S/H
Total = $2087.92
And please if anyone finds anything on my list cheaper or not correct please say so I will post it in my thread as well…
