I am building an RC mower using a 36" twin blade mower deck salvaged from an old MTD riding mower. Drive will use two NPC wheelchair motors with an IBC controller and differential steering.
I plan to use a series wound  motor salvaged from a mid 60s vintage golf cart to drive the blades.  It is rated 1.5 hp at 2800 rpm and 36V/40 amps.  I will use a contactor to control this motor.  Can anyone comment on the suitability of this motor for this application?  I think a shunt wound motor would be better.  Is there a possibility of overspeed when the blades are not loaded?  I thought about starting with 24V and checking the performance.
-enganear
