I had 2 thinks with the same issue. Both turned out to be the relays under the hood. There are 2 of them. They are the same so you can swap them to see if the lights come on. However, I suggest replacing both relays.
Does anyone here know if the DCDC needs to be isolated? I need to purchase a replacement and see isolated and non-isolated converters.
You should use isolated
Thanks, do you know what would occur if I used a non isolated unit?
Plenty of people use non isolated and they claim they havenāt had any issues.
I purchased one and it appears to power up everything as normal. I havenāt been able to drive it to see if it behaves differently but sitting still itās working normal. Maybe I will mount it onto a delrin plate rather than direct to the chassis.
Can I get a manual bubbat1121@gmail.com
