I cannot see an attachment. Did you append it to this email?
See if that worked. If not, you have to get it from someone else as Iām overseas for 4 weeks.
I feel like a parrot Ive read this so many times, but Im in need of the wiring manual too. Thanks for helping. chuckenglish1@hotmail.com
Hey Coach- Iāll send you what I have.
thanks assy. I would love to have it. When I told my son about asking for it, he said probably not going to do us much good. (Hes the fixer and Im just the driver). He has changed controller to a curtis and wiring also.But if is shows the 12v stuff that would be handy. If I had known that I could have included that in my description 23" tires, battery fair, brakes good with curtis controller. Cant remember number. Will check with him and get that. He says people will probably bash him for using it and say its a forklift controller but it was fairly inexpensive and it works.
sorry. think I put that in the wrong thread
Did you get? Maybe check your spam folder?
My outbox shows it went out. Maybe it was clobbered somewhere because it was close to max allowable size. The folder was pretty fat.
Curtis controller
The original GE controller that came out of that car is also found in forklifts, sweepers, and all sorts of service carts. That is nothing to be slammed for.
You can put in whatever works for you. If I find a deal on a Think, the first thing Iād tear out would be that cluster!!
The only concern about doing anything non-standard is that this car now becomes yours. There are not too many people that would know how to work on it. Resale value will not be as high.
Sorry assy⦠didnt get diagramā¦thanks for trying . already axed the cluster. Son is doing the work on it⦠Hes kind of a geek about electronic stuff. Buys and sells elec golf carts for a hobby.
Sent again.
(To the above hotmail address)
Got it⦠Thanks assy⦠I can do the pdf file but not sure about the zip⦠Im old and not that technical savvy
I can also send unzipped if needed.
Most of the time if you just double click (or whatever you do to open things), the zip will automatically unpack and build a folder of itās contents.
Hi David, can you please send me the manual?
My email is naomj1201@gmail.com
Manual sent >>>>>>>>>>>>>>>>>>>>>>>>>
How do I post to this forum
I need a manual can you help me John 9163338180
Hi David would love to get a wiring diagram for my 2002 Ford Thinkā¦. Thank you so much David. My Email is MDCompton@sbcglobal.net
Manual sent >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Hi David Iād like a copy of the wiring diagram and if you have other documentation too jim_dunphy@comcast.net. I acquired a rolling frame of a 2002 Ford Think truck model the only thing it still had was the break pedal and the dc converter so basically building it from ground up
Hey dunphy,
Clarify if you wouldā¦
Rolling frame to me means no wiring or the various modules (like the dash display(aka cluster).
No body plastics?
If so- you will need more than just a wiring diagram.
Suggestion -
Depending on your intent, you might consider buying a harness from an ezgo and use cart parts on this.
The body plastics, the truck bed, seats, DC/DC and the wiper assembly is what was on the cart when it was given to me. So Iām looking to source the Motor (72V), the controller, solenoid, charger, accelerator pedal and the main harness ( orange high voltage one only i donāt have a need for the low volt one ). Once all of that is installed the plan is to build a bypass much like hagan92 ( Fordthink.org ) has done since I donāt have a need for lights/horn etc. I can find most of what Iām looking for but a complete main harness is proving to be difficult so Iām looking at the possibility of creating one.
