Rather than hijacking the 29mph thread, I’m starting a new one.
May on be of interest to only a few.
Testing results of field weakening “only” on T4 7.5hp.
Top speed on level ground = 34mph with MM1/2. 12/1 gears. Stock tires. Poor batteries.
Max arm amps 245.
Stock setting is 65 = 2.1 amps.
External circuit reduces minimum F current 25%. 1.6 amps minimum or equivalent setting of 62.
Seems field weakening alone does not produce noticeable results on my Gem.
I have not reprogrammed F7 to 62 for a test of my circuit math.
Would this be expected result. Going from 65 to 62?
lets clearify a few things .
Dave,
I real world changing from 65 to 62 gives you only a small increase in speed. going all the way down to 55 might give you 10% . the biggest change is fooling the speed controller ( like your mm does) or by changing rolling radius or gear ratio .
i’d like to hear about how you are externally dropping you field current. between this and your mm your doing some unique things .
shunt motors love voltage , thast why they slow down so much when batteries get low . they can get the amps but not the volts . my guess would be if you were to add a 6 volt battery in series with your 72v batteries and charge the whole thing to 84 volts instead of the current 77.4 (12.9X6) your cart would accelerate faster then all of the controller mods combined .
Rodney,
fyi changing #7 does not give the motor more amps, it changes the field ratio so the motor rpm’s increase giving you more top rpm . you do give up a little torque in the top end but its not very noticeable .
[quote=kinghappy;29289]lets clearify a few things .
Dave,
.[/quote]
That is on my to-do list for my doggy 48v tomberin if programming doesn’t help.
I really want to do the 6v add on battery thing on my e2 , but I cant find a 6v gel battery that isn’t a monster. may have to try and find a used 6v gel monster and just prove concept.
the lithium pack I run keeps voltage much higher then the gels , the difference in acceleration and top speed compared to a stock cart and even a reprogrammed stock cart is pretty amazing .
it did over 40mph with a stock 5hp motor and I never have an over heat problem .
so i’m pretty sure adding more volts to a stock battery setup would work well .
My plan is to add a lithium cell or two.
Single cell chargers are common. It would have more capacity than other batteries, so it would not need to be monitored closely.
[quote=Inwo;29303]My plan is to add a lithium cell or two.
Single cell chargers are common. It would have more capacity than other batteries, so it would not need to be monitored closely.[/quote]
so you would setup the onboard to just charge the 6 gels , then put the lithium at the end of the series and charge it with its own charger?
as long as the gels would discharge quicker then the lithium it should work .
I take that back. Having trouble finding them now.
6 months ago, I got this quote:
Hi
Pls check pictures, 10A and 20A are the same appearance.
The quotation for 3.65V 10A charger:
100 pcs ---------18USD/PCS
200 pcs -------16 USD/PCS
The quotation for 3.65V 20A charger:
100 pcs ---------28USD/PCS
200 pcs -------26 USD/PCS
Are these aluminum case with fan?—Yes.
Pls advise me your quantity.
Thanks Amy
Usually, they will send samples for same price. Shipping would be a big deal.
