Delta Q error code
Yesterday our GEM e825 made 2 routine trips to the beach. Afterwards it was plugged in as normal. Today the dash shows 1 red line, it had about 1/2 charge when plugged in yesterday.
The Delta Q charger is flashing 4 reds. According to my manual that indicates and AC out of range.
Please help. Let me know how to correct the situation.
Shorter/larger cord. Use outlet near breaker panel.
Check for melting connections on a.c. Gem wiring.
Thank you. I replaced the 16 gauge cord with 12 gauge and all is well.
