Hello all, my car recently stopped charging I believe e. It will show full charge and then die after a few hundred feet. When plugged in I get an almost immediate 4 red flashes on charger.
One possible cause shows the power input is not up to spec.
- Make sure the outlet you are using is good. Maybe try another one?
- Make sure you have a quality power cord going to your car. 16ga and as short as possible. 12ga is better.
- Make sure your connector on your cart is clean and not melted from a poor connection.
You should also check your batteries.
That battery display is lying to you.
Thanks. So I followed what you said, it’s still blinking. I’ll check the batteries im trying to charge them separately now.
What batteries are you using?
What profile is your DQ set to?
