I recently installed a charger from it Q on a golf cart and when I connected the wires I accidentally touched the green wire to the battery negative, since I had already connected the positive, with that caused a spark and now the led is flashing red 6 times… Can I do something to fix it?
That short circuit blows an internal fuse.
Is there any way to fix it buddy?
That fuse is NOT easy to get to.
Where are you located Bird?
São Paulo, Brazil…Can I find a picture of this fuse here on the internet? I really need to fix this charger because it’s not mine ![]()
I have a few chargers apart here. I will take a picture and send it to you.
Check your PMessages (upper right of the screen- click on your B)
