Inwo
April 28, 2019, 12:14pm
#1
Does it hold back at 25mph? A mm may be all you need.
That’s the configuration that I thought you had. Exactly the information I’m looking for.
I believe that no balancing was required when you tested first charge cycle?
Most of the time bottom balance gets messed up by trying to balance cells on the top. Even a monitor connected to them may cause more issues than it helps.
The conversions I’ve done are running “free range” with only unconnected balance leads on some for easy testing.
The …
I have a few more batteries tested from the same batch as these.
5 x 5s 16v 60ah modules to replace 6 lead batteries.
Uses original charger and wiring.
$1250
