I bought a 24s Pack from @LithiumGods, I’ve hooked everything up with a 300A ANT BMS and it’s working very good, I didn’t have chance to do big testings because I have another things to fix fist before start hammering the pedal, however I found a good deal on a 400A Daly BMS and I pulled the trigger.
Look the size of that thing (use the battery cells to compare the size) I’m impressed with the quality, it looks very Robust compared with the ANT one
Daly has an excellent reputation . It is a little overkill but that is fine . I like the fact that it is waterproof . Remember to hook up big battery cable first Before you connect the balance leads . Does it have bluetooth ?
