This is chapter 2 from my earlier planning thread - 2016 e4 - Build Plan?
To recap - I bought a 2016 back in March from a Polaris dealership in St. Louis, MO. Looks like it was used as a shop/customer vehicle and came with 300 miles on it. Probably spent more time outside that I would have liked but overall, it was in good condition and I think I got it for a decent price. Plus side, since I’m the first non-dealer owner, it’s actually under warranty (although I’m probably going to void most of the warranty with this thread.) I got it shipped safely and inexpensively with George who’s now on the forum @GHTransport and shipped a bunch of stuff for others on here.
My 2 big requirements are 1) need it to be able to go 35+ mph uphill (ideally 45-50 wot) so I can keep up with traffic and not get run over and 2) 25+ mile range.
Ended up settling on -
- 8kw AC motor (pre-drilled by @Inwo)
- Secon S4 80v Controller (programmed by @MikeKC)
- new style gearbox with modified 12.x:1 (bought off @MikeKC but the gears were installed by @Old_Houseboater.) Will try skateboard mounts for sound isolation.
- Delta-Q charger
- Tesla Model3 20s battery split in 1/2 by @Inwo and wired up to a JK BMS (Shipped by @GHTransport, along with the motor and charger).
It took me a while to dive into this project. Was accumulating parts, finishing up some other projects, and life just got in the way. Finally got a chance to dive in. I’ll try to post as many pictures as possible as I do the conversion with the hope that his helps someone with a 2016+ conversion down the road.
First step, out with the old which happened in 2 phases.
Phase 1 -
Removed the rear stake-bed and battery compartment cover. Pulled the batteries and donated them to @smspring who was having battery issues. This would get him going until i could help him with a lithium conversion.
Then I was on a month of travel and decided to dive in again this past weekend. I was amazed at how easy it was to break-down the car and pull the rest.
Out goes the battery tray by removing 4 bolts and then I dry fit an empty case identical to the one that has the tesla battery. It fits like a glove!
Moved onto the front. Pulled the hood, pulled the charger, and removed the front-end plastic. Picked up this little tool from amazon to make removing the plastic rivets easier.
Out goes the controller, phase wires to the motor, motor, and gear-box. I managed to get the gear-box out without removing the axels from the wheel hub.
Maybe 2-3 hours tops to get all that done? Considering it’s all similar equipment going back in, I’m hoping the reverse doesn’t take long.
2 silly questions for those that have done this before
- Have you installed a main disconnect switch? If so, what did you use?
- Suggestions on how connect battery B+ and B-. I think I might be a few inches short to the factory cables. Can I just make a foot-long cable with battery lugs on each end, run a bolt through it, and heat shrink it?
Goal for early this week is to get everything physically installed and then I can start wiring. Will post as I make progress!
