After reading all the exciting posts about the A/C conversions folks have been doing and the reports of enhanced performance, I’ve decided to take the plunge myself! Over the past few weeks, I’ve been accumulating parts from @Inwo and @MikeKC and getting ready to dive in. Finally got a chance to get the car up on jack stands and start ripping things apart. Posting here in case anyone wants to follow along.
About my car and what I’m planning to change in this build
2000 4 seater
Original 9:1 gearbox which is leaking and needs to be rebuilt -> 12:1
R4Fun Blue motor -> 16’ Gem 5Kw AC motor
T2 Controller -> SevCon Gen4
Original shocks -> QA1 per @Tyson_Davis shopping list A little fresh air(shocks) never hurt anybody
(4) 2kWh Chevy Volt batteries (may add 2 more packs upfront)
DeltaQ charger w/ lithium profile (stay the same)
Chargery BMS (stay the same)
Goals -
I have a huge steep and long hill I have to go up and over to get anywhere other than the grocery store with my GEM. I don’t need to break any speed records but would like to be able to maintain 35mph so I don’t get run over on 35 mph roads. My typical trips aren’t usually more than 10 miles round trip so range isn’t a huge concern… but who doesn’t want more range! Ride is crappy at best (not surprising with the earlier GEMs)… hoping the shock kit that worked for @Tyson_Davis works for me.
First false start before even starting. I bought this kick-ass motor from @Inwo
When it arrived, I started doing some rough measurements and quickly realized there was no way this was going to fit. Problem is that the early GEM have the gearbox dead center to the car, while the later GEMs, the gearbox was off-set closer to the driver’s side giving more space for a longer and bigger motor. Even if I messed around with wheel spacers and moving the suspension, it was going to hit the steering knuckle and just not work.
Back to the drawing board and brainstorming with @Inwo and @MikeKC, I figured we needed a smaller motor and @inwo had a 5Kw motor he was willing to part with. It’s about 1.5 inches longer than the R4F/D&D motor so I figured with some shock adjustments I could make it work.
Played the father’s day card to get some time tinkering in the garage and ripping everything apart. Was able to pull the old motor, gearbox, axles, shocks, and controller. Turns out the original gearbox is leaking oil, the axles need new boot clamps (I’m going to replace the boots while I’m at it anyway), and the blue motor probably needs to get re-worked because of the oil getting thrown around (I’m going to get it rebuilt by @Old_Houseboater anyway knowing that I’ll probably rebuild another GEM sometime soon).
check out these shocks
Got the 12:1 gear box re-installed and now I’m waiting for parts to re-grease the axles, replace the boots, and some spline grease/paste to mount the motor and reattach the axles.
Taking a break to tend to the ribs on the smoker and organize the garage. Will pick this up during the evening this week and post along the way!
