I did put chargers on the back batteries last night and then charge the whole system overnight the cart is working so so far so good thank you again!
That’s it? You pulled the cord and want off the bus?
Fine, Be off with you…
Hey! By now, I know you know that I am a needy individual. I need help on a regular basis thanks to my purchase of something I really don’t understand that well and needs a boatload of care on a regular basis. What do you think of the next time I need batteries going lithium?
So now you need to run it down a little bit and charge(onboard) then let it sit for 1 hour and then measure the voltages of all 6 batteries. They need to be without ~.1V to .2V worst case. If you need to, put your single battery charger on any low battery and take it upto the high battery level. This will balance the charge in all the batteries and hopefully get you a much better experience when you run your pack down towards the low end.
Noted and thank you!
