05 gem question
I have just purchased a 2005 gem it had all gel bat. That were all bad .I installed all new deka acid bat. …the charger is the delta Q charger. I’m I ok or does my charger have to be reprogramed for acid bat.
Yes, the algorithm must be changed for wet batteries. The procedure is covered in the manual below.
Daniel
[QUOTE=GEMmechanic;10968]Yes, the algorithm must be changed for wet batteries. The procedure is covered in the manual below.
Daniel[/QUOTE]
Thank you that was just what I was looking for…Scott
[QUOTE=Delad54;11005]Thank you that was just what I was looking for…Scott[/QUOTE]
thanks again just went out and changed for wet batteries…But what would of happened if i did not change setting from gels to wet ???
I recall that the charge algorithm for wet batteries calls for a higher finish voltage. This would result in wet batteries being undercharged if used with a charger set to a dry battery algorithm. This will not, however damage wet batteries. Just don’t try to charge dry batteries on a charger set for wet. That would result in an overcharge and eventual damage.
Daniel
