I 'm going to be running one of these motors at full power for a duration of 6 minutes:
http://www.bphobbies.com/view.asp?i...27&pid=B3675243
The device that I want to build will be be used for a tow unit which will tow a paraglider pilot into the air via a 3000 ft long line and a drum hooked up to the motor, all of which the pilot will take on board with him. Thus, it is critical that the unit and the battries be very low-weight.
Any idea where I can get my hands on batteries like the li-ion shown here?
It appears they are running 10 kw motor at 60 V and 167 amps for a total of 25 minutes of sustained flight time using a prop. I don’t need nearly that much power or duration, thought the the electric paraglider developers seem to be using this same battery, thus I assume they found the most effecient way to go by choosing these types of batteries. I have no clue where to find them, though.
Check out this video if you like. Now that is en expensive electic toy!!:
http://paramoteurs.tv/spip.php?article281
Thanks for your help!
- Ivan
