[QUOTE=piersdad;10505]with batteries in the blade the G forces could be immense and the batteries could be crushed.[/QUOTE]
You could be right - quick idea to test this: Determine the Rotor Blade Length, subtract a few inches back for where the last battery would be placed, and make a small blade spinner (Private Centrifuge, if you will), put a max recording ‘G’ Meter there (A simple analog one from Aerobatic aircraft, correctly oriented for max positive G’s), and gradually spin it up to 10% of normal and max rotor RPM’s, then 20%, 30%, etc. until 110%, Checking the Maximum G’s recorded at each run, before resetting and starting the next Higher RPM Run!
If there is the possibility - you might want to put in the test rig at the place where the G-Meter is, a small RC First Person View (FPV) Video Camera to Record the G-Meter while testing, as well as while testing the cells.
Nobody lists the G Forces their batteries can take - so now you have your very own G-force Tester for Batteries!! And Voila, your new business:
“G-Force Research Institute, Inc.” (Government Grant’s - anyone?)
After you know the G-Forces at each run, you can then test one set of cells at the same point, knowing you are getting those same G-forces at that point, and you can determine - at the cost of the test rig plus one set of cells - if your idea is correct.
Remember - the Tesla Motors team went through a large number of Cells - testing to Destruction to determine the many failure modes, so as to determine how to overcome the failure modes, just for finalizing on a Cell, Module, and Pack Design!
Oh - the idea of testing the G-Forces and Cells survivability might be able to be numerically simulated in a FEA (Finite Element Analysis) 3D CAD Design, or alternatively, using CFD (Computational Fluid Dynamics), so you would not have to build a test rig, but the Test rig might cost less, than the modeling time on a high end FEA / CFD System!
Robert Weekley
