Not quite.  The S10 will go about 100MPH now with a 125HP 2.8L V6/auto engine in it.  The 96 Tahoe I used to to have was much larger with a larger wind profile and was 1600lbs heavier, and would go somewhere north of 130MPH with a 210HP engine.  And, there’s little incentive for the auto makers to do anything more than is required to meet the EPA standards existing at the time.  Whether such a thing is possible is not relevant, whether such a thing is PROFITABLE is.  You’d think that selling cars that get extreme mileage would be very profitable for the automobile companies right now, but they fight tooth and nail against anything that requires an increase in MPGs.  Sometimes I wonder if the oil and gas industry and the automobile industry aren’t heavily invested in each other, which would make selling large gas guzzlers the most profitable vehicle all around.  Sell the vehicle at a premium, then keep making money off it at the pump.
The Prius isn’t what I’m after, it is an ICE driven vehicle with electrical boost on it, which is what makes it a hybrid.  The ICE still provides power over 35-40MPH or whatever, and both of them together provide any high power boost needed for passing.  Having two different motors driving the car’s drivetrain via a mechanical connection is what makes it a hybrid.  What I’m after is no mechanical connection between the ICE and wheels, making it a diesel electric vehicle instead of a diesel electric hybrid.  This also means that my diesel engine would only run at whatever RPM was required for it to turn the generator at its required RPM, usually about 3600RPM.
Higher speeds can come later if necessary, I rarely drive over 80MPH anymore but I do tend to cruise 75-80MPH.  I just want the capability of going up to 125MPH on occasion.  Initially, being able to go 75MPH max would be great.
From the Tesla website:
“The
pack operates at a nominal 375 volts, stores about 53 kilowatt hours of electric energy, and
delivers up to 200 kilowatts of electric power.”
The Tesla has on board, after a fresh charge, 53KWH of power and has a range of almost 250 miles at highway speeds.  Since they use the standard EPA 55 HWY 45 CTY driving cycle, this will include some regenerative braking input, which is really just putting back lost momentum, not actually adding to the power.  So under strict highway driving, 250 miles of range should be correct.  This means it’s just using 212WH per mile to move the car.  Am I reading this correctly, and if so does this not mean that a tiny generator would be able to power a Tesla?  I mean, show me how I’m wrong here.   Does it really take this small amount of power to move the car?  Is my math off?  I’m not trying to be argumentative here, just trying to see why I’d be wrong about this if I am.  I arrived at 212WH per mile by dividing 53,000 watts as listed by the Tesla folks divided by 250 miles to get the watts used per mile.  And this is assuming that there’s no low voltage cutoff on the car and it uses the full 53KWH of power, or that it does have a low voltage cutoff and the 53KWH is what’s available for use.  I can almost generate 212WH of power by strapping buttered toast on a cat’s back and dropping it.  This is the power needed to run a 100 watt light bulb just over 2 hours.  And if I’m correct, then there’s no reason for this to not work, but I don’t know what size generator would be needed.
In answering this, remember that the folks that build the generators to extend the range are moving the car, plus the generator, plus anywhere from 1000 to 2000lbs worth of batteries.  And, their goal is no ICE at all, different from my goal.  They could easily mount a larger generator, cut battery weight, and extend the range indefinitely.
EDIT - I just saw what I missed, that 275WH isn’t per hour, it’s per minute.  Need a generator that will generate 30KWH to drive this thing.   Thanks folks, I find this very, very disappointing, but now I understand why it won’t work.
MODEL NUMBER 	5402
ENGINE 	1.6L Generac 4-Cylinder
ENGINE RPM 	3600
VOLTAGE/FREQUENCY 	120/240 Volts / 60 Hertz
LP POWER CAPACITY 	30,000 Watts
NG POWER CAPACITY 	30,000 Watts
FUEL TYPE 	LP (Propane) or Natural Gas
NG FUEL CONSUMPTION (50% Load) 	300 cu.ft/hr
LP FUEL CONSUMPTION (50% Load) 	3.3 gallons/hr
COOLING SYSTEM 	Liquid-Cooled
LIMITED WARRANTY 	2 Years
WEIGHT 	935 Lbs.
DIMENSIONS 	62.2"L x 29"W x 33.5"H
MOUNTING PAD 	Concrete (Not Included)
DECIBEL RATING 	73.0 dB @ 7 meters
ENCLOSURE 	Steel
