I have been known to drag race from time to time.
all depends on budget and pack capacity.
275WH isn’t per hour, it’s per minute, because you need that to go 1 mile, and traveling at 60MPH, you are moving 1 mile per minute. So, you need to generate 275WH/minute, or 16,500 watt hours, to travel 60MPH. Believe me, I wish it weren’t so, but it is. A generator also runs best when it is not run over half capacity, so you should ideally double the requirement for the generator. And that makes for a huge generator. Just the generator head is 38 inches by 18 inches by 22 inches, or thereabouts, way too big to fit under the hood and still have a 200HP engine to turn it.
where did the 275 come from anyway? I thought you were talking about the 240Wh/mile specification from Tesla. Stick to one number, and preferably the correct one. Also, it IS 240Wh/mile, not minute. You can’t just start throwing miles per hour at it and expect to get the data you want. You need to get the associated units to cancel out.
On wikipedia “Dynamometer testing in August, 2007 of a Validation Prototype on the EPA combined cycle yielded a range of 221 mi (356 km) using 149 W·h/km (4.17 mi/kW·h) battery-to-wheel and 209 Wh/km (2.98 mi/kW·h) plug-to-wheel.[9][38]”
Since we want Wh/mi, its 1000/4.17, which is 239.8Wh/mile. If you had a 239W load, and ran it for an hour, it would be equivalent in power useage to what the tesla uses in one MILE.
Lets say we wanted to go 60 miles. (Average 60 miles per hour) and it takes an hour.
240Wh/Mile * 60 miles= 14,400W is what it uses in that distance over the course of an hour.
So you would need to generate 14.4kW in an hour, which is 14.4KWh. Now, yes, you could do this:
14400kWh * 60min/1hr = 240Wmin, but I’ve NEVER seen any generators rated per minute, its always per hour.
I know you went from A to Z, but again, its hard to follow when you tell me 275Wh/mile is actually minutes… that is ONLY true when you ASSUME that you’re going 60 miles in an hour. Which you only JUST said, so how would I have known?
