Thank You… that was a lot more optimistic than some of your other posts
Even though this is a relativly new thing it seems that everyone has already thought of everything?
haha, I’ve been working on it a little
But yeah, people talk about adding generators, alternators, wind turbines and solar to their car. You need something that is light and can get you a good power to weight ratio. Solar is up and coming, just not there yet…at least not cheaply.
Ok, so originally the idea was to draw some more range out of the bike so when its parked where ever I am some more power heads to the bats rather than nothing at all. But for the money i guess I am looking at your typical high po after market parts, like CF wheels, and various other bits.
If its parked, you’d be better off trying to ask work to install a charge area… or drive to places with outdoor power. The NEXT best thing would be to lighten that frame up, and take everything off you don’t need.
Liion bats I swear i saw somewhere that the power needed to run the bike at the current cost of batteries puts the bat cost at $9000 ? That is way too much. Can you add Liion bats as you go to a Lead Acid system?
You wouldn’t be able to fit in $9000 worth of bats that easily. I’d estimate if you wanted 40-50 miles, at 150Wh/mile (actually high), that puts you around 6-7000Wh, and you’d need around 22 cells (~72V). that would give you 7040Wh. 22 cells, at 200 a pop, is 4400, much more affordable. Plus BMS, plus charger. Not too bad actually. I’m going to see if I can’t source some 50Ah batteries, maybe even 40Ah. Just depends. I’ve seen 20Ah bats for 33 a piece.
10 times the money doubles the range? I assume that there is a weight save as well?
Yes, lifepo is roughly 1/3 the weight of lead for more Ah. But also, lead is more stiff and can supply MORE hard current under acceleration. it seems that right now, lifepo isn’t giving people the current output they need for larger cars, but for Motorcycles, its fine.
Ok I’m going off to read more… If anyone knows of a Liter Bike in the VA area with a bad motor cheap let me know.
crazedlist.org (its a craigslist search engine that allows you to search ALL OVER the country, not just a local city. Found 2 bikes on there remotely for people.
Thanks for putting up with me
I did the same thing when I started researching 8 months ago… now I’m almost done with the bike. Its easiest to get a bike and plan the system around it in my opinion. That way you chose a motor that fits, a controller to match the motor, and what you’re left with is a shell with enough space for batteries. Remember, make Lead fit right now, get her going, and upgrade to lifepo. You shouldn’t mix battery types, but you can get a small pack (48V) and run, then upgrade to 72V and beyond.
