My pedal at the zero to just get a little moving speed is very touchy. Actually it sort of goes right past crawl to moving but not full throttle. It seems as there should be a little more taper at the beginning of the cycle and speed start up. If that’s normal then ok, but i feel its not. If its not normal, is this what i should look at to replace?
I know with the AC controllers, this is tunable… The dead space in the throttle. I’m unsure with the T2 controllers. It might be. Folks on here would know
