I recently purchased a 2016 gem e6 from auction that wasn’t doing anything I got it powered up and ran the dash and found it had a throttle position code . I ended up putting a new throttle from eBay in it and got it to move . It seems slow going forward . In reverse it moves like it should but when going forward it seems a little slow it will get to about 10/15 mph and seem like it doesn’t want to go too much faster is there a way to relearn the throttle or any other pointers ?? T.i.a
I doubt that it’s throttle issue, as it would throw a code.
You can test to make sure throttle is going wot.
Use meter in neutral on the 4 wires. Use b- as ref.
2 wires = 0v
2 wires = +5v
1 wire ~ .5v to 2v
1 wire ~ 1v to 4v
From memory. I can connect a throttle on the bench to see. In any case for. and rev. get the same throttle data.
It may be that car has speed key.
Just By chance the switch is not in “slow”, golf course speed mode to the right side of steering wheel?
Another hit and run! ![]()
