I’ve owned my 2012 E6 for about a month now and recently moved to a more hilly subdivision (I’m in Texas so I’m talking very slight slopes). My old neighborhood was completely flat and sometimes it would max out at 15mph and then I had to come on and off the accelerator a few times to get it to go on up to 25mph. In the new neighborhood, and slight hill will cause it to max out at 15mph and will not get up to speed until I’m back on flat land or downhill. I don’t think it’s a power issue as it feels like it limiting the speed vs not having enough power to continue to accelerate. Gel Batteries are at 78V+ and I have a range of 25+ miles and the car is completely empty (except for me the driver).
I have not Ohmed out the accelerator PINS yet but I plan to do that next. I’m coming here to ask first if this is normal or a safety feature before I risk messing something up with the cart by tearing parts out. Any input would be greatly appreciated.
Looking at it, do you think you are up for it?
Not rocket science, but need some testing skills. If I knew it worked I’d start selling something.
Send $200 deposit? Refund when I get it back.
Okay. Finally got a chance to test with the ohm meter. I’m getting 2600 when not depressed and it evenly goes down to 750 when all the way pressed down. I know this is a little off from the manual 3k to 800. Could that be the issue? Also something to note - when I’m in high gear, I’m maxed out at 15 but in low gear, I’m maxed to 7.
Are you sure 7 is the correct pin? I’m getting no reading. I was using the cigarette outlet as a ground. It was only me and I didn’t have any clips to clip to the negative terminal. I’ll try again with my wife’s help but just wanted to confirm the pin.
Ok. Checked again and same thing. No reading. I plugged it back in and now I’m getting error code 21 and the gem will not move at all. Error 21 is: 21 accelerator fault safety lock out inspect accelerator resistance and wiring. Next step to just replace the accelerator?
