The need for speed
I have a 2005 Gem with a bad controller. I would like to do a speed upgrade (at least 35) while I am at it. What seems to be working well. I see guys that offer to rebuild controllers and 7.5hp motors. Already have 195-14 tires and wheels and from what I read 10.35 : 1 gears. Has anyone had any luck at this?
Thanks for any help.
Which controller?
What problem?
T3 and I am pretty sure it is toast. I followed the flow chart in the service manual pretty close. I am just looking for folks that have made this up grade to get their opinion of the results.
Yeah - as long as your controller is bad any way upgrade to a T4. The T3 is pretty limited.
For 35MPH you will have to up grade your motor to a RFF. motor.
At 35 MPH with your setup you will be turning 5500+ RPM. A stock motor doesn’t like over 5000 RPM for very long. If you stay at 30 MPH it should live forever.
Thanks for the post. Is it a big deal to change to a T4. And point me toward an RFF motor that is new to me. Was looking at a blue motor but!
DandD builds Ride for Fun And MZ Motor Sports (Blue and Black) motors.
What is an RFF motor. is The D&D motor a good setup.
Ride For Fun is the dealer D&D is the manufacturer
What is involved in changing from the T3 to a T4 controller. Are they a direct replacement
I think there is someone in FL that can flash program the T4. Any Idea who it is?
To what effect? Correct speedometer?
I’m looking for a junk T3 if you end up with one.
My 2010 5hp 12/1 EL runs 35mph with 24" tires and MM. Lead and T4.
Motor may not last. Not an issue for me.
Can’t be worse than running 100 volts in my E4 7hp.:slight_smile:
See signature…
Not sure about the T3 vs T4 issue, just trying to learn a little. I was told that the T4 could replace the T3 and had more turning chooses and understand I don’t know this for sure that is why I am asking you guys.:noidea:
I believe you are correct, that’s why I’d like to have a T3. To look for work arounds.
Some have issues with speed. http://www.electricforum.com/cars/gem-nevs-forum/9953-gem-wont-go-over-29-mph.html
Some not. http://www.electricforum.com/cars/gem-nevs-forum/9976-2005-build-update.html
Hi
if you not get over 29 did you try to change software in your T3 ?
try to change from GL7L to GL8L
An explanation on how to do that might be a good idea. Also a reason why.
This is new information not posted before. Educate us as to what this is and how it might help us please.
Firmware?
Is it available?
I can program a t4 to do what ever you would like .
The man to see and he’s in Florida… very reasonable fee.
