Thank you Brian
Turn the key on.
Push and release the TRIP/ODOMETER switch until it’s showing the
odometer. -
While holding the switch down, turn the RIGHT signal on, then the LEFT
signal, then return the blinker to the center. -
Release the TRIP/ODOMETER switch. You should be seeing data (P0105) on
the display now. -
Turn the RIGHT signal on, then off repeatedly until the display reads:
SOC (State Of Charge). -
Push and release the TRIP/ODOMETER switch. Now it’s remaining capacity in
percent. -
You can now raise (or lower, for that matter) the SOC with the blinker
switch. -
When you’re happy, Push and release the TRIP/ODOMETER switch. The display
reads: DONE. -
Turn the key off.
