Well when I first put the Leaf cells in my cart I noticed that’s the volt meter read less than what I had in the actual pack. But it it didn’t stop charging and it’s still charging. Has anyone else noticed this? I have 20 modules in my 2005 Gem.
I should have only taken one pic that shows 00 even when I turn the key on. These two pics are from when it was still charging. Either way with the key on it moves but shows 00 on the dash.
When battery is full voltage, see if you can reset the 00 to 99.
It’s done with turn signal lever. Instructions are posted somewhere on forum.
Thanks Dave! I’ll look for that.
Troy Hoggard’s iPhone
On the 05’ and above models the dash displays I am familiar with read the percentage of charge based on an algorithm it uses. It is not a voltmeter and is never a good indicator of the true pack condition.
State of Charge Indicator
- Turn the key on.
- Push and release the TRIP/ODOMETER switch until it’s showing the
odometer. - While holding the switch down, turn the RIGHT signal on, then the LEFT
signal, then
return the blinker to the center. - Release the TRIP/ODOMETER switch. You should be seeing data (P0105) on
the display now. - Turn the RIGHT signal on, then off repeatedly until the display reads:
SOC (State Of
Charge). - Push and release the TRIP/ODOMETER switch. Now it’s remaining capacity in
percent. - You can now raise (or lower, for that matter) the SOC with the blinker
switch. - When you’re happy, Push and release the TRIP/ODOMETER switch. The display
reads: DONE. - Turn the key off.
Thanks Russ appreciate the time and help
Man Dave you’re the best tech support. Really appreciate the info. I wasn’t sure what to search for.
The Display can be programmed,so sad i dont buy these cable then Chrysler have it now i think its gone
here is old number for software and cable,maybe also possible to change parameters for lithium
1015-00221 INSTRUCT INSTALL PHOENIX LCD ,CD/Software new polaris number 9923769
0115-01645 ASSY Wire Harness
maybe inwo also can build this cable
