Keep an eye on balance. May have to turn it on and set lcd to stay on longer.
Only balances when set to “on” and display is on.
I don’t balance during charge and discharge. Seems a waste.
Default balance is 10mv which is too tight for me. 20mv is plenty.
Set your fuel gauge in menu. I set from 3.5v to 4.1v.
If you plug in alarms, set levels where you want. I don’t bother.
Thought about sensing motor and controller temperature, but never got “a round tuit”.
This Spark Kit is amazing. Up the steepest hill I still have room onnthe gas pedal to “power up” example my normal speed up the hill is around 20 MPH at best. I have lots of room onnthe gas pedal. Smash down and another 5mph it’s amazing super happy thank you David’ this thing rocks
Thank you,
Another hardware hack, if I can find it, is padding the throttle pot.
Changes to a non linear pedal response. First 1/4 has reduced affect.
Watching for data.
This is 1/2 pack. 19/2=9.5kwh=40 Spark miles🤓
My test of 150w/mile give >50 miles in theory.
For longest life limit high and low volts. I only charge to 4 volts unless more range is needed. A button press on bms raises charge hvc.
And now for the bad part.
Runs too fast. Need to slow it down.
Seems to be a problem with battery monitor or cable to the display.
T1 and T2 don’t like high voltage.
