I would like to have a copy of the pdf as well.
Thanks,
Ken
[QUOTE=kenkidd;1723]I would like to have a copy of the pdf as well.
Thanks,
Ken
kenkidd@yahoo.com[/QUOTE]
sent on over to you
Put me down for a copy of that as well, Im looking at starting an EV motorcycle project.
marty.vanhoeckel at gmail.com
[QUOTE=gonnafail;1728]Put me down for a copy of that as well, Im looking at starting an EV motorcycle project.
marty.vanhoeckel at gmail.com[/QUOTE]
has been sent
i would aslo like a copy of the pdf, depending on what it is i may post it to my site
to the guy with the 12 hours to print pdf 15 minutes to start printing doc
your computer is broken or malfunctioning. ‘no’ document print should take more than a few SECONDS to start printing even on ancient hardware!!!
what are your specs? cpu? ram? OS? printer?
[QUOTE=nerys;1751]i would aslo like a copy of the pdf, depending on what it is i may post it to my site
what are your specs? cpu? ram? OS? printer?[/QUOTE]
not true, PDF files are weird like that. they have to convert the file for the printer to read it (thus the delay on the printers side) then it will print it as one big file… its like the printer putting together a puzzle while using a rubics cube to sort the peices.
and i need your e-mail address to send the book over to you.
sorry i assumed as a moderator that you could see my address
use: evforum at nerys dot com
also i still need the specs your info is just not correct i have a 233mhz pentium tablet with 64meg of ram running windows 98 and it takes less than a minute to get something going on the printers even the laser printer. windows ‘spools’ the file to the printer there is no ‘reconstructing’ of the pdf in pdf is not even a format. its just a container for other components such as images text docs etc… it sends the file bit by bit. most printers today lack the memory for even 1/2 the page at a time. lasers of the old style can be an exception where they must fully load each page before it can print it therefore limiting what you can print such as imaged.
also add to those specs what software your using to read the pdf’s with
[QUOTE=FEUS;123]I have a PDF I found online when looking to research some more on electric vehicles, but I dont know if anyone has anywhere that I can host it with so that more of us can use it. It has lots of great info on it, so let me know and I’ll send it accordingly.[/QUOTE]
This sounds like an interesting document to read but how have all the others that you have sent a copy to indicated its usefulness in the design process of an EV. Yes gas costs are killing most working families when it comes to there earning a living and once you reduce that earning with the cost of fuel to get to and from work you begin to wonder why you travel so far for the job. It is that you can not get a job in your feild of expertise or maybe for other reasons but the end result is you still end up with less in your pockets as energy costs continue to rise.
I would like a copy as well SpaceNutNewMars yahoo.com
[QUOTE=SpaceNutNewMars;1766]This sounds like an interesting document to read but how have all the others that you have sent a copy to indicated its usefulness in the design process of an EV. Yes gas costs are killing most working families when it comes to there earning a living and once you reduce that earning with the cost of fuel to get to and from work you begin to wonder why you travel so far for the job. It is that you can not get a job in your feild of expertise or maybe for other reasons but the end result is you still end up with less in your pockets as energy costs continue to rise.[/QUOTE]
sent to both of you, as a moderator i could look to see your e-mail address, but its easier for you to list it.
as far as how much the book helps out… its up to the person… it mostly provides you lots of different formulas and math equasions for the proper power to weight ratios and what not. along with basic ideas for building an EV.
as far as costs… you dont need to build an EV that costs a ton… heck… make an EV bike… thats what i’m doing… i’ll probably spend a grand total of about 1-2K on the whole thing… dont have to worry about the weight problem, and i can drive it in the summer no problems
(saving me at least that much in gas if not more…)
I’ll take a copy please
[QUOTE=camillo;1799]I would also like a copy of the pdf.
Thank you
Jason
camillo@pokeanosepottery.com[/QUOTE]
it wont go through, it says the file is too big, get a g-mail account or something and it will send easily.
[QUOTE=FEUS;1800]it wont go through, it says the file is too big, get a g-mail account or something and it will send easily.[/QUOTE]
ok Try this one
Thank you
jason
could i have a copy also please?
dbrown134@hotmail.com
[QUOTE=dbrown134;1819]could i have a copy also please?
dbrown134@hotmail.com[/QUOTE]
why of corse
they are sitting in your in box
thank you very much
Dave
[QUOTE=Rabbit’s Leg;1824]FEUS,
If this pdf is sitll avaliable, can I have one copy?
Thank you!
liching1102@hotmail.com[/QUOTE]
yes it is available and you have it waiting in your mail box
HI, may I have a copy too…
It’s hard to find good info on EV
Thanks so much
Rocketman
