Need to know where the 2 wires coming out of the bottom of the charger connect. 1 goes to the key switch but the other has come loose and I need to reconnect it. I had a friend do some work on the steering column and it got disconnected.
White and black wires?
Those are ignition lockout. They go to a green and green/red wire (at least that’s the colors on my 02). Doesn’t matter what order. It’s just a relay that opens when the charger has power, which breaks the ignition circuit so you can’t drive away with the charger plugged in.
Thanks much it makes sense now.
