I have some numbers on my Gem that I am trying to figure out. I used a lot of the recommended settings from others but there are a few that are a lot different than another user that sent me his original settings. I am not sure where to put the settings at.
Below are my suspicious settings…that i think are wrong
Lines:
22 Odometer Calibration - mine is at 150
23 Error Compensation - 30
24 Field Weakening start - 36
27 Hour Meter Minutes - 30
28 Fault Counter Pointer - 32
29 Hourmeter 10/1 - 64
30 Hourmeter Auxiliary 10/1 - 64
33 Fault 1 -77
34 BDI 1 -100
Through my Hourmeter 8 is filled mostly out through line 63 whereas another users wasn’t
97 Odometer .1 -3
98 Odometer 10/1 -49
99 Odometer 1000/100 -12
Any help is greatly appreciated.The other lines checked out with another user and then i used settings recommended on this forum for the rest. The ones above are the ones i cannot figure out if they are right.
