New 2008 type throttle repair/upgrade
New 2008 type throttle repair/upgrade. In theory, no need to open potbox.
Not ready for prime time.
@AssyRequired
In any case. Here is a good working hall pedal. .5v to 4v tested.
Should work in any Gem as fs1 uses dry contact relay. T1-T5 ok. T1 may require 12v to 5v reducer which I can supply and test for you.
$200 or try a search. I have not been able to find or price it. My source is unknown. Let me know what you find.
5 posts were split to a new topic: Site ads and blocking
Something for 2002 welding pedal.
2002 pedal works with T4, so 2008 type pedal should work with 2002. Correct harness shown below.
I made a reverse harness by mistake. Can’t think how it could be useful. Testing welder pedal in a 2008, possibly. Or replacing a bad 2008 with a welder pedal. Unlikely I’m sure, but the mistake was made. :frowning:
Conversion harness allows a bulkhead mount hanging pedal to work in older cars. Mechanically, I have no idea how it would fit.
Reverse harness, mistake, below.
