Hello all,does anyone know of an accelerator pedal generic or from a GM vehicle that works on 2008 gem?2005 GM truck looks identical except too many pins on connection. I opened mine up and cleaned contacts with brake cleaner and worked for a couple weeks,now back to same thing,barely moves,thanks
I have new pot boxes built that plug in and work. Need to re-use your petal.
$225
Okay I’ll look into those,thanks for the information
Inwo pedals are great. half the price of factory
do you still have pot box if so how much are they? thank you I thought i had one but it was the wrong pedal
Did your other guy fall through?
Yes, I have some ready to go.
how much are your pedals
he showed a picture of the one i needed so i said ok but he sent me a pedal for a 2013 - 2015 gem which does not work so i returned it so i am back to square one
Interesting. I was working with someone the other day and somehow that pedal was adapted to work in the Gen2 cars. I did not see how it was mounted tho- . Some bracketry witchcraft no doubt.
Sorry to hear it didn’t work out. It sounds like Inwo might be your next source. Or I can back him up next week.
2015 requiires more power than t5 can suppily. Iirc
Mine are tested with t4-t5 for full output.
$225 + $15 s&h priority.
PayPal barbjb@acegroup.cc
i just sent $240 via PayPal for the pedal please let me know if you received it thanks
Tracking Number
Shipping Address
Shipping From
DAVID BISSEN
100 FALLS ST
HOKAH, MN
55941, US
Shipping To
RONALD CASE
70 CASE LN
PONTE VEDRA, FL
32081-8801, US
I need a pedal for 2006 GEM E4.
Message @Old_Houseboater for price and availability.
If not, I can sell new potbox only. $245
@AssyRequired may also have something.
Fyi, test wot voltage at pin 7. If not over 2.75v you are net getting full torque. Less torque means lower speed on level ground and up hill.
Not all throttles can demand full torque. Notice my picture showing 3v + wot. Rodney tests all the ones he sells.
Do still have any? I need one for a 2006 GEM E4
@Johneverhart -
What makes you think yours is bad?
What are your symptoms?
