Anyone know of an affordable accelerator pedal for a 2008 gem e4?
I might be able to help with this.
What makes you think you have a pedal issue? (symptoms?)
Hi,I’ve took the pedal apart and cleaned the contacts,runs for about 5+ minutes,if it sits for a few hours or overnight it will go again for another 5+ minutes,I’ve also bought a gm pedal that looked and plugged identical but was different inside,used some of the internal parts and that lasted about 2 weeks,batteries are good.now same thing,only pedal I found was over $500 from polaris,thanks for reply.
Yep- Pedals are tricky. It sounds like you have a failure that I am familiar with. Inwo and I spent some long hours figuring those things out. We have yet to find an off the shelf plug in ready unit that is compatible. I have several hundred dollars in pedal units that WON’T work. If you only have one, consider yourself lucky.
The good news is that we have a solution and can get you one for far less than $500. Give me a couple days and I’ll get you one.
That would be great to find a reasonable replacement or repair,let me know if you find something,thanks
