My e4 won’t go at all , middle last year had new batteries , blue motor, and controller reprogrammed. Could get 30 mph ,ran fine for 6 months or so now nothing, put new directional switch on and bypassed key switch same results. Any ideas. Thanks so much for y’all’s knowledge
Display working ?
Any codes on display ?
Hows your 72 volt fuse in fuse box
Loose battery connections
Possible bad gas pedal
Blown main fuse under seat.
Batteries not fully charged
We’ll we checked it all out and think it’s the (gas )pedal Switch looks like It may be bad , do I have to buy complete assembly or can you by just switch? Thanks in advance
I saw on here a Saturn gas pedal assembly would work. Any one know which part number or description? Oem is 500$
I used ultra-power part number 699138 from rockauto. Just to make sure you know, this is not plug and play. You have to cut and attach the pedal assembly and add an external switch.
Thank you I’ll see if my mechanic is confident to do it. Thanks again
I looked the part up and have one coming , for the price difference I’ll pay someone that knows what to do with switch . Thanks
