2010 gem car accelerator pedal issues
Hi my 2010 gem car has been having issues with the accelerator pedal where only one spot in the pedal will allow you to go full speed, I’ve tried looking into options on new pedals but haven’t come up with any good solutions. I’ve tried an 2002 envoy pedal which looked very similar but didn’t work when plugged in. What are the current options for these?
Rodney @Old_Houseboater usually has some replacement pedals.
Ask @AssyRequired , he is getting into it, as well.
Ohhh’ choices!
Who do you want your parts touched by?
do you have accelerator pedals for sale or repair parts for a 2008 GEM if so how much are they thanks
I think that I have one.
$200 exchange.
ok how do i get in touch with you thanks
@jenniesdad
Q- What makes you think this is a pedal issue?
What is the car doing/not doing?
car would not move swapped the pedal from my working gem and the non moving one worked fine
Any error codes?
Where are you located?
no codes i am in st augustine fl
Sorry, I’m a bit under the weather. And busy! If I get going again, I’ll let you know.
Maybe Byron can help you.
thank you no real hurry
I sent you a private message.
(look up at your avatar)
You got this Byron?
I have an internal switch version on the shelf, but have not had time to test.
Yes, I can pick this one up.
any updates on the accelerator pedal thanks
I can get one out tomorrow. See our private message thread and you can give me your address.
