my car 2005 just get stuck in to charging mode (plug in sign show on displace)
all the light are working . the car not move at all due to in plug in mode. battery seam ok. charging system seam ok with all the charing light. Is there any way to get to reset the system . thanks you for all input advice.
Did you try switching the battery cut off switch on and off? Or pulling one battery terminal off a battery?
