Can there be a bypass switch for the Magic Magnet?
Will the MM object [release smoke or otherwise become non-functional] to being powered up with no load on the in or out signal wire?
What about extending the MM wires into the cab?
Only need to switch the green signal wire from motor.
Use two poles to break both green wires to mm.
Open circuit is fine.
Dpdt should do it.
I could also buid one special with a remote dip switch, i guess.
Most of the mm have the switch exposed above the potting.
It can be broken off exposing 6 pins. 3 are common ground. 3 are 1, 2, 3.
3 has the largest affect. Solder 2 small wires to ground and 3, then route to a simple on-off switch.
Two get back to original 1+2 setting, bend the #1 pins toward each other and solder.
I will do it if sent to me prepaid return, for the experience.
The basic idea is to be able to use a relay wired into DL to bypass MM.
I was just clarifying that the MM isn’t harmed by the signal wire being open, with the power on
DL is 15mph which is what the school zones are in Reno, I live in the middle of several blocks of Pedestrian Safety Zones with 20mph speed limits, which are targets of enhanced enforcement depending on the time of the month
With the dip switches wired remote, some relay logic, various levels of speed control would be possible
Last I saw the MM price is $135, how much extra $ and lead time for remote dipswitch setup?
1/2 pedal = 25mph on flat ground
20mph, full pedal for overpasses & hills, I’m guessing is due to reduced pack voltage/current more than T4 settings or motor
I don’t have enough battery to go faster, nor am I convinced of the need…
I think if you are getting one finger salutes, you waited too long to let them pass or should choose a different route
GEMs are no different than any other, machine, make em work harder, they break more often, in new & exciting ways.
Malicious Compliance. certainly is a source of entertainment here, at the very least allows JrJava to try out new material
I can get one out next day. However that will be Monday now.
Remember that the mm will not reduce the speed limit.
However it can double the limit of turf mode.
Also it has no affect on power it only raises the limit.
Open circuit is not a problem.
On a side note. You can connect to remote relays such as rfid or key fobs.
Is the Turf DL Profile for the controller output different than the DH profile?
Current, Voltage, Field, Ramp, regen…
Is running for extended periods, 1/2 pulses in turf mode going to heat up the motor or T4 controller?
