Do you have this product for a Gem eM1400 2014? I like to speed up from 19 mph to 25 mph or higher.
Arie Klapwijk
The Netherlands
Arie Klapwijk
The Netherlands
No, It needs controller programmed for higher speed.
@Ariebaas - To clarify- The MM works based on a principle used in calculating speed on DC motor driven cars.
Your GEM EM1400 uses an AC motor. Speed is calculated and regulated in a very different method that is much more complex to adjust/bypass.
It’s almost like they didn’t want anybody messing with them?
At least the emmy Sevcons are not locked. Turn up max speed in motor settings and max rpm in main drive profile
I can also add two more drive profiles for say, turf and eco modes.
I need hands on controller.
Any golf cart or ev guy with Sevcon dvt can do it.
Gabe may be will ing to customize a speed box for Ranger. It has been discussed.
Gabe may be willing to customize a speed box for Ranger. It has been discussed.
His singature (if it matters)
Glad you clarified that 25mph would be ok. eM’s have 17:1 gears, to get to 35mph on the stock tire size, you have to spin the motor at 10000 rpm. You risk damage the bearings at that point.
