Where can I get a magic magnet for my 99 gem ?
@Funjohnny - 1. Are you sure you have a 99 Gem?
How much do you know about it? Is this a 72v car?
Or maybe a 48v?
- What motor do you have in this car?
It’s 72v system . 99 E825 with zivan charger .
Ok, Now can you answer the second question?
(Bonus points if you can answer within 21 days)
Stock motor I have never replaced it ,
Odds are that the MM will NOT be able to help you. -Sorry.
Oh yeah it will.
When it grenades that anemic 3hp and he gets to buy a better one.
Definition “grenades”: the catastrophic destruction of your gem motor due to an owner over revving itbwhile the end bearing fails, pieces fly everywhere, often accompanied by a flash, fireball, and lots of smoke. © @Old_Houseboater .
Where do I buy a Magic Magnet for a 2008 E4 7.0? Thanks in advance for the assistance…
$135
Leave a note
Hi David, do you have a Magic Magnet that will work with a 2002 Ford Think NEV with the 6HP motor?
I do, but it needs to be hard-wired. Different plug.
Ps.
I’m not sure it’s needed. Will your car run with sensor disconnected?
Thanks for the prompt reply!
I haven’t tried running with the speed sensor disconnected.
The motor thermostat and the speed sensor are on the same plug.
I’ll unplug the sensor/thermostat plug and jumper the Thermostat back to the motor controller and see what happens.
I have a 2020 gem e6 What do I need to do add 5 mph ? Thanks
Speedbx will get you up to 35 mph on flat ground
Can I buy one of these for my 2020 GEME6?
Hi Dave I’ve come across your name few times now, recently bought 2007 Gem E4 gets to 25mph quick then holds. Will your magnet work on my car? I’ll try attaching pic of motor & controller.
thx Mike 1mge@comcast.net
D&D Motor Systems model 170-501-0002B manftcr date 2/2022, serial #1244. 7.5 hp, 72 volt, current 95/8, rpm 4950. Sure Power controller model 710301, serial #06005764. input 72VDC-96DC
Yes, will work perfectly to remove that 25mph speed limit. Standard settings will not limit until 40mph.
2007 speedometer can be set to read 0-40 corrected speed.
Great thx for reply, my son bought this Gem to tinker with so I’ll pass info on to him. We’d be happy with even low 30’s as then can safely drive on more local roads here in SW FL. Were waiting on front arm bushing delivery from NEV and installing front brake pads soon. If rides smooth & don’t need CV’s or ball joints then we’ll order magnet, what’s the latest price? thx again!
$135 Leave a note. Ships to PayPal registered address.
