Hi all, I purchased a lithium upgrade from @Inwo a while back and was working great until my stored gem stopped charging due to low voltage (2 flashes at Delta charger). I had a timer periodically charging my gem over the winter but my plan didn’t work clearly. Here is a screenshot of my BMS. Is there a way to get the charger to charge my battery under this condition? Thanks!
Turn on Emergency mode in control screen.
Thank you I’ll give it a try when I get back there in a bit.
So I turned on emergency mode and tried unplugging and plugging in the powered cable but no luck. Still stuck with the delta two flashing lights. Any other suggestions?
Good news, after toggling the setting a couple times and plugging the cable in /out it started charging again. Thanks for your help Inwo!
The preferred method for short term (1 to 4 weeks) storage is to shut down the battery switch (leaving the BMS active). So you can check in on it from time to time.
Long term (2 to 12 mos) → Shut down BMS.
The old “set a timer” plan is not necessary and has too much potential for failure (as you noted).
Okay good advice, I’ll follow that approach next time. Thanks
