Lithium ion
Does anyone have any tips or instructions for converting a car using lithium ion batteries. Thanks.
[QUOTE=adagan;2104]Does anyone have any tips or instructions for converting a car using lithium ion batteries. Thanks.[/QUOTE]
make sure you have the money to buy all the other parts for it too since they are not cheap.
i seen this today thought it worth alook
http://www.beepscom.com/product_p/ba-lb-200-48.htm
Build your System Voltage by putting these Lithium Iron Phosphate “Packs” in Series. Two packs would make 96 volts and Three Packs would make a 144 Volt System. Thus, for under $20,000 you can have over 2,000 fully Drained Cycles. At over 100 miles by Pack Life this would be well over 200,000 miles before you would need to replace your pack.
The 200 Amp/Hr Batteries have a C3 Continuous Rating of 600 Amps and a Peak of up to C11 or 2200 amps.
Approx Size: 17.2" Wide by 17.6" Long by 13" Tall
Approx Weight: 236 Lbs
Thanks for that info, I’m trying to find the cheapest lifepo batteries. This company Coolgreencar is selling 16 KWH for $16,000 the site mentioned above is 48 volt for $6,395 Could someone help me figure out the difference.
at $16,000 for 16 KWh = $1000 per KWH
The other one is 48 volts times 200 amp hours =9.6 KWH. $6400 for 9.6 KWH = $666 per KWH, about 2/3 the price
