License Plate Light
How do I replace bulb in license plate light. Have 1999 gem e580 48v.
I imagine the bulb is actually a standard auto 12V bulb driven by the onboard DC-DC converter. If so you should be able to simply remove the cover, pull out the bulb and replace it.
Al
The cover is the problem. Does it just pull off
I have no detail drawing
[quote=suesamh;17512]The cover is the problem. Does it just pull off
I have no detail drawing[/quote]
That particular question I can’t answer. If the whole bracket comes off, it may be that the screws holding the cover are accessible from the rear of the bracket when it’s off the vehicle.
Al
Thanks will give it a try.
