Info on Display Settings Menu
Hello out there,
Does anyone have detailed information on what each of the settings are in the display menu and what is affected by changing them?
This is how you access the settings menu on the GEM display:
Turn the key on. Push and release the TRIP/ODOMETER switch until it’s showing the odometer.
While holding the switch down, turn the RIGHT signal on, then the LEFT signal, then return the blinker to the center. Release the TRIP/ODOMETER switch.
This is a subject that’s not very well known about. It would be great for others to share what they know
I just used the SOC setting today to adjust the battery meter for my new 99V Spark battery. I noticed the other menu options but did not instigate them.
