I’m back at the state park again for the winter. And, of course, the GEM car needs help. It is a 2008 GEM eL. It was down for awhile waiting for wheel parts. That’s done. Batteries are charged. When turning on the switch, dash display showed but GEM wouldn’t move. Then the display would go off. Now the display only shows once in awhile if you jiggle the key. But it doesn’t stay on. I’m thinking it is the switch itself. How do I access the switch? I just had a knee replaced 6 weeks ago & the other one is scheduled for Dec1 so my mobility is limited for now. I can get a ranger to help me when needed. Would like to fix this before I go in for the next knee replacement.
This was mentioned in a previous post: “Echlin KS6040 from your local Napa autoparts store.” Would this switch work on a 2008 model?
Many thanks,
DICK
On edit: When I plug in the unit, the display shows the plug icon and the battery charge icon. (Battery is fully charged)
Switch is replaced and display lights BUT Gem won’t go. No sounds like it’s trying to go. No codes or wrench on display. Is there a troubleshooting chart available somewhere? Accelerator problem? Motor problem? Fuse? Unit was originally disabled due to a front end part broke. That got fixed and then the switch problem showed up. GEM was running up until the front end problem.
With the switch off and the parking brake DOWN do you get an alarm? If not Check the parking brake limit switch and connections. This is a common problem.
You can download a "GEM CAR repair and maintenance manual here for 5 bucks.
Pedal is suspended type.
Went back to shop and tried GEM again and this time it threw code 81 (speed control) for an instant and then it started to move. Couldn’t take it out of shop to see if it keeps running as we have a broken down tractor parked behind it. Will test it tomorrow.
