Hello,
I purchased a 912-7200 Delta Q Charger to replace the original silver charger. The new charger hooks directly to the batteries and charging the batteries work perfect. Now the problem, I thought I could just unscrew the 9 pin connector at the old charger and remove it but that makes the charge icon on the dash light up. Does anyone know what the easiest way to delete the silver charger would be ? Can I just run a wire from pin 13 (Charger Inhibit) to the battery negative ?
Thank you.
Robert
