Ok cool sounds like everyone is somewhat on the same page. Looking forward to getting this ball rolling.
O here is some addition info on the Transmissions Dave has
Will Team transmission internals work with Comex transmission internals?
Another example 2013+ Gems came with “shafer” brand transmissions they were a (Dana Spicer) copy. You could not use parts from a Spicer in a Shafer and so on
I wonder what transmissions are the Orignal good stuff? The Comex
or the Team?
Comex brand. And this is why I don’t do phone. ![]()
For everybodys information the correct length of the shaft only is 15 and 3/4 inches with a 1/4 thick washer fitted on outboard CV joint as a spacer. This is a 10.35 transmission. I would also be willing to go thru the box to try and determine the whine.
How is the shaft measured? The solid shaft or the compressed assembly?
Also, what is the spacer for?
The solid shaft 15 3/4
the 1/4 spacer moves the joint inward on the hub because there was a concern of thread length being too long on the 2016 hub which is narrower. Possibly not necessary. but if omitted would require change shaft length.
I was at a disadvantage because I didn’t have a cart to develop the shafts on. Mike would fit what I sent then report back and I would make changes. The reason Length is so critical is because the joints have limited travel. Cant be too long or to short. Getting the manufacturing process down to where the shafts were strong enough took 3 tries. The 2nd one is still out there some where but I lost track of it.
I believe that Rodney is correct on the length. I thought the whine could be coming from the half shafts and I took a swing at shorting them up. I was way too short.
15.75" should be the length of the solid shaft spline end to spline end.
So a pirate walks into a bar with a ships wheel mounted to his belt buckle and says…
If your putting this in a classic or a late model keep me informed. I have an avid interest in where and how my products are used. We know the transmission can handle the speed but don’t know at how hig a speed. The 6 to 1 gears were used in EZGO carts years ago. I can still get the dear set.
Yep, will do. Right now it is sitting on top of a stack of tires and the half shafts might be going to @Inwo
Send it to Rodney if you want it fixed.
I only wanted it to look at shafts.
Trannys, shafts and sway bars oh my…
My Gem has been on jack stands since ~ Dec 2021 lol
I do have it and it’s going to @ScottyD
I also have the other 10.35 you did
Gabe what are you doing with the 10:35
I thought we were talking about the Schafer/Rodney 6 to 1
Gabe may trade. So hold on.
@grantwest is yours R4F gears? Or equivalent?
Trade for keeps or for testing?
That one is going to @ScottyD FedEx picking not up today
@grantwest i need to finish testing 10.35 with oem car and torque map modified and then I’ll be ready to trade it for a 12.1
Hold up for Gabe swap? Or is Rodney doing a different ratio?
@rodney what’s up here?
