I would go Double pole single throw since there is only an on/off function required
What say you?
What say you?
If you wire like original. DPDT
One way is fan only. Other way is fan and heat.
IMHO
I’ll buy that
Got a part description and source?
Radio shack has a switch I used to use in heavy duty 36vdc operation. It’s only rated 12vdc, but that should be fine.
1/4"qc terminals. Plug in swap.
So - how about one of your neat little schematics?
I think it’s a controller board.
Thanks,
Jeff
This will not work the way I suggested, but I found it while researching switches, and don’t want to lose track.
A 20A switch rated 125vdc. :eek: :eek:
I’m not buying it. Yet I contacted the manufacturer and verified it.
Heavy Duty AC/DC Motor Control Toggle Switch - DPST / On - Off : 30-10342
quote
Hello Dave.
The DC rating on this product is the same as the AC rating for both voltage and amperage.
altexlogo
Matthew Rodgers
Sales Representative
11342 IH 35 North
San Antonio, TX 78233
(210) 637-3200 x1224
(210) 637-3264 Fax
Altex Computers and Electronics
end quote
Not my best work.
I’d still like to get my hands on the old switch.
Agree How about running it around the track again and label connections. Other people are having the same problem, Once this proves out it will probably be a good project for the DIY section.
Thanks guys, Do you need anything from me? What “ringing” the switch?
Thanks,
Jeff
Another way to say continuity check or ohms check.
You would check for connections between all combinations of terminals.
Then hold switch in other positions and do the same thing.
In a standard switch it’s obvious. This one is a puzzle.
Those middle two terminals could connect in many different ways.
[quote=Jsrrags;27225]Thanks guys, Do you need anything from me? What “ringing” the switch?
Thanks,
Jeff[/quote]
Yes I think that since were doing problems at long distance without schematics, and this is a significant problem for other people it would be GREAT if you sent the old switch to Inwo after your operating again. We can learn a lot by analyzing the switch configuration.
How about this.
This wouldn’t need a ground?
I will send the switch just shoot me your address.
Thanks,
Jeff
[quote=OLD HOUSEBOATER;27228]Yes I think that since were doing problems at long distance without schematics, and this is a significant problem for other people it would be GREAT if you sent the old switch to Inwo after your operating again. We can learn a lot by analyzing the switch configuration.
Rodney[/quote]
If it works as I hope. A 3PDT switch might make an exact swap. But at this point. Who knows?
[quote=Jsrrags;27232]This wouldn’t need a ground?
Thanks,
Jeff[/quote]
Not if it works the way we think. The ground would be for the input to circuit board thru the switch.
I’ll know more when I see the switch.
Check pm.
:clap2::clap2::clap2:
I think we could probably have worked together
Thank you,
I jump from forum to forum depending on my interest at the time.
I must say you are a friendly bunch.
Any chance it was an illuminated switch.
I keep thinking, why the ground?
