Goliath Battery Install 2017 Gem
The big one that @LithiumGods showed is touch screen, the small one in my pic is not, it has a button on the side,
I couldn’t find a good place to mount the big one tbh otherwise I would have used it. the small one shows exactly what I need SOC, amps and voltage.
Ant bms questions:
I have a 22s Tesla battery using 450a ant bms.,
Need to use MaYi v1.3
Also just built a 23s Goliath id.4 using ant 450a bms.
Need to use BMS v1.0.0 ant icon with this one.
I have a message in to icgogo about latest apps and if there is one that works with all ver ant bms.
@grantwest you reported issues changing parameters. What app do you use?
What is name of bms when you connect?
I have 24c ID 4 pack in my car with the 400Amp ANT BMS. I have never been able to program the BMS and Have the settings Stay. Example I can go in and change things but the setting never remain. My pack is balanced and running well but who knows. I bought a Cheep Android tablet to program it. In fact when I got the latest I phone software ANY BMS is not available
Byron has an app. I’ll post a link if icgogo comes through.
Been using JK and had no problems, if it throws error wire resistance it will clear after power cycle the bms
Good to know. You cut the balance current; I assume. I wonder if they make a 200a on with low balance current.
I have a system to remove the end plates but hate to do it just for jumping fuses. I may consider it.
Limit balance current to 0.5
easy to limit balance current. will check if a 1a balance version is available.
